| Posted by dale peck on March 16, 1999 at 22:28:54: | |
| In response to Re: noise from drain | |
: I have a bath room with two sinks. Recently when the water in either bowl goes down the drain there is a small gurgle. This bath is our master bath and used the most. no other drain seems to do this. I suspect the problem is in this drain only. What should be done, the water doesn't hang up or anything, the noise is after the bowl are drained. : thanks mike m try a drain cleaner and see if that helps. Dale, also the vent could be partly plugged with soap and hairs. |
| There are none. |
