| Posted by mike m on March 16, 1999 at 19:41:52: | |
I have a bath room with two sinks. Recently when the water in either bowl goes down the drain there is a small gurgle. This bath is our master bath and used the most. no other drain seems to do this. I suspect the problem is in this drain only. What should be done, the water doesn't hang up or anything, the noise is after the bowl are drained. thanks mike m |
