| Posted by dale's plumbing service on March 15, 1999 at 05:06:42: | |
| In response to Re: Propane Piping | |
: I have been told to use black threaded pipe to install my propane appliances. I was then told, by someone else, that this pipe "flakes off" inside when used with propane and that I should use copper instead. What's the story. Appreciate the help, thanks. you should use black pipe on propane. copper and galvanized pipe are the ones that flake off. galvanized is ok by the code also for natural gas and propane as far as i know.STAY AWAY FROM COPPER!!!!! |
| There are none. |
