| Posted by Terry Love on March 13, 1999 at 13:46:59: | |
| In response to Re: Leaking TP valve on new gas H2O heater | |
![]() : : : : : The old heater had the problem of a leaky TP valve for about the past year, BUT NOT prior to that. Is it normal to not need one (expansion tank) and then all of the sudden need one? : Dean It can if something like a check valve has been added at the water meter. This is becoming more common as utilties add measures to prevent back-flow contamination. Disregard the water shutoff on the hot side of the picture, it should be on the cold inlet side. Terry |
| There are none. |
