| Posted by Keith L. on March 09, 1999 at 15:50:20: | |
| In response to Re: Pressure Tank Control | |
Before I'd change the switch I would increase the "cut in" pressure to 25 or maybe even 30, I think a 15 psi differential is typical. Jacking the max psi to 50 may be a little too much depending on what your outlets are, some sink designs can leave the user somewhat wet when initial pressures are high. |
| There are none. |
