Wrong Placement of 1/2" distribution lines in uninsulated exterior wall
Posted by Lou on March 08, 1999 at 21:34:32:
In response to Wrong Placement of 1/2" distribution lines in uninsulated exterior wall
If you have to do it be prepared to do it again. You would be better off opening up the top and the bottom of the walls you have to go up, and feeding the copper pipe up from the basement through new holes. You should only have to open the walls enough to fasten the pipe to backing. Most of the soldering would be done in the basement.......Just a thought........Lou
Replies to this post
There are none. |
