Re: interior concrete slab repair
Posted by Tom cassidy on March 08, 1999 at 21:26:41:
In response to Re: interior concrete slab repair
Hi: The problem you have is can be fixed easily with a diamond grinding wheel, this will smooth out the surface and allow the tile to stick. A problen you do have is that concrete needs 30 day(28 to be exact) to fully cure and allow the moister to leave. if you cover up this area before you will be trapping moister and your tile will not bond.
Replies to this post
There are none. |
