Re: remodeling and installing hot tub
Posted by dale's plumbing service on March 07, 1999 at 18:39:01:
In response to Re: remodeling and installing hot tub
: I am remodeling my home by installing a basement under it. I want to put a room in my basement big enough for a four person hot tub. I am not knowledgeable of hot tub installation, and I am wondering about such things as room dimension, floor preparation, ventalation, etc. Is there any good info out there you could direct me to? if you put a hot tub in a room inside of your home you should do all the walls & ceiling in ceder or red wood.as far as ventilation check with the manufacture. the room size depends on the hot tub size and how much room you will need around it.i personnally would not put a hot tub inside. do a lot of checking out on this and get a knowledgable contractor who may have done it before.
