Re: new pipe
Posted by dale's plumbing service on March 06, 1999 at 19:30:25:
In response to Re: new pipe
: Two questions.
: I am replacing very old 1/2" copper water pipe coming from my water meter. I have ok water presure. Would I gain anything from increasing the pipe size to 3/4". It is 3/4" coming out of the water meter that steps down to 1/2" after about 6".
: I am redoing a bath. Took out an old tile floor and plywood subfloor. Hardwood floor now shows. The problem now is that the toilet flange is now about 1" above the floor. As a temporary fix while remodling I have 3/4" plywood under the base of the toilet. Is there an easy way to lower the flange or am I stuck raising the floor.
a 2 bath house with kit,washer and 2 hosebibs carries 19 fixture units. a 3/4" line is required and the code states that a water service line shall be no smaller than 3/4".i always run 1" for future expansion. as far as the flange goes they have a flange called TWO FINGER FLANGE you can cut off excess pipe and slip this flange down inside to floor level.only for cast iron or dwv sch 40 pipe.
Replies to this post
There are none.
