| Posted by dale's plumbing service on March 06, 1999 at 19:17:15: | |
| In response to Re: No Hot Water Pressure | |
: Could be small or big. Sometimes "crud" to use the technical term, can get in the valve stem area. Removal and cleaning of the stem may be a help. Sometimes, problems are more involved. It could be that pipe has closed down. It will take a bit of detective work to come up with a solution. Terry : : The hot water in my Bathtub trickles out very slowly. It literaly takes 45 Minutes to fill the Tub. The pressure in my sink ( hot and cold) was low and I canged the Screen Trap and now it's fine. The Tub however is just the Hot water. Do I have a serious Pipe problem? And is repairing something like this a Do-It-Yourself item? Or does a Plummer need to come in? take the stem out of the faucet and try flushing it out.sometimes removing the seat in the faucet will allow a larger piece of foriegn mat to pass.Dale |
