Re: No Hot Water Pressure
Posted by Terry Love on March 06, 1999 at 17:43:49:
In response to Re: No Hot Water Pressure
Could be small or big. Sometimes "crud" to use the technical term, can get in the valve stem area. Removal and cleaning of the stem may be a help. Sometimes, problems are more involved. It could be that pipe has closed down. It will take a bit of detective work to come up with a solution. Terry
: The hot water in my Bathtub trickles out very slowly. It literaly takes 45 Minutes to fill the Tub. The pressure in my sink ( hot and cold) was low and I canged the Screen Trap and now it's fine. The Tub however is just the Hot water. Do I have a serious Pipe problem? And is repairing something like this a Do-It-Yourself item? Or does a Plummer need to come in?
: I have a tiled shower, and seperate Hot/Cold taps. I ahve no problem breaking into the tile if need be - I just want my hot water back... Any suggestions would be greatly appreciated.
Replies to this post
