| Posted by Terry Love on March 04, 1999 at 19:59:13: | |
| In response to Re: new pipe | |
![]() : Two questions. For a one bath home you could get by with 3/4" pipe. For anything more, heck even for one bath, go ahead and install a one inch line from the meter to the home. The existing 1/2" line is not enough for even one bathroom, much less adding a kitchen sink, washer, hosebibs, ect. : I am redoing a bath. Took out an old tile floor and plywood subfloor. Hardwood floor now shows. The problem now is that the toilet flange is now about 1" above the floor. As a temporary fix while remodling I have 3/4" plywood under the base of the toilet. Is there an easy way to lower the flange or am I stuck raising the floor. Without looking at the material for the flange, hard to say. If access is good below the floor, that helps. |
| There are none. |
