| Posted by Terry Love on March 03, 1999 at 21:42:40: | |
| In response to Re: replacing bathroom floor with tile, will raise floor 1", cause problem with toilet? | |
You can use three wax rings, with a horned one for the top. You will need to use the 3-1/2" closet bolts instead of the 2-1/4" Terry : I am taking out linolium tile flooring and replacing it with tile. with the cement board and the tile, the floor will be raised about an inch. Am I going to have a problem when I go to put the toilet back in place since the floor will be higher but the toilet drain still at the same depth? If so how do I extend the drain up an inch to get a good connect?
| There are none. |
