| Posted by Dennis on March 01, 1999 at 13:33:45: | |
My shallow well water pump turns on almost immediately after we turn on any facet in the house. I would guess that the 15 gallon vertical pressure tank does not have enough initial air pressure. The pressure gauge shows only 50 pounds--which is the rating of the pump and there is no obvious signs of a leak down. What is the procedure to recharge this 150 psi tank to improve this situation? Thanks |
