| Posted by David Hoerl on March 01, 1999 at 12:48:30: | |
I've heard that if you use ball valves instead of the "normal" water valves one finds in houses, that you get much less noise when water flows through the valves. Is this true? I'm having a house built and wondering if I should specify ball valves for use in water main, hot water heater, etc. Thanks! |
