Re: hot water !!!
Posted by Bud..Suncoast Plumbing on February 28, 1999 at 21:20:40:
In response to Re: hot water !!!
Pete:--You might consider upgrading to a 50 gallon water heater with a firing rate that will not necessitate increasing the size of your flue piping. If you have enough room in your home, a storage tank of similar size will assure that you won't run out of hot water...Bud
Replies to this post
There are none.
