outdoor water supply above ground
Posted by Doug Knight on February 27, 1999 at 15:47:11:
I have been told in Alaska water lines are laid on the ground and are insulated. The line is made up of two lines an inner one, which carries the water and is collapsable, while the outer one is the insulator from the elements. If this procduct exists I would be interseted in finding out where it can be obtained.
thank you.
Doug Knight.
Replies to this post
There are none.
