| Posted by Lou on February 27, 1999 at 15:33:24: | |
| In response to Freezeproof Sillcock Repair | |
You should be able to access the washer from outside. Remove the handle, then the packing nut, the stem should then screw out. The stem is as long as your frostproof sillcock, allowing easy access to the washer. The seat on the other hand is another story.....Lou |
