| Posted by Terry Love on February 24, 1999 at 23:49:38: | |
| In response to Re: finding a sewer line | |
![]() I would check with the County first, to see if they have records of either the sewer line or the septic location. Another trick you may try, is witching for it with some wires bent in a "L" and held in each hand. When the wires cross over the pipe, they will align with the pipe. For some reason, the left wire and the right wire will point at each other. This works on plastic pipe, and metal pipes. You may want to practice with a pipe laying on the ground. Terry
| There are none. |
