Re: Kohler tub
Posted by Frank on February 23, 1999 at 12:36:50:
In response to Re: Kohler tub
This is the time to put that tub access door in. Should have been there in the first place. Then get a toe pop-up, through out the plug, insert a basket strainer to catch hair, and use a plain old rubber stopper for baths. Much more efficient and clean.
: : I have a kohler Villager tub and the stopper (clean out ) is jammed. Any suggestions? There is no access without breaking the dry wall.
: boy, your in a mess. can you spray wd40 down the overflow tube from the top. take a pair of pliers and grag the rod and keep on working it. if you do not succeed then you have no choice but to cut the wall i guess. good luck. Dale
Replies to this post
There are none.
