Re: toilet mount
Posted by bbj on February 23, 1999 at 07:31:50:
In response to Re: toilet mount
: After removing the toilet in preparation to lay tile in the bath, I found the following:
: 1. the flange was held in place by the lead collar only and was not secured to the concrete floor.
: 2. the concrete around the flange is not flat and true.
: Should I anchor the new flange to the concrete floor, and should this area be leveled? Will the additional height of the tile create any problems in the installation? The floor was previously covered with vinyl flooring.
you want to have
1. an anchored level flange and
2. level floor.
3. even commercial 1/8" tile thickness not a problem-- your wax seal can deal with it.
Replies to this post
There are none.
