Re: How to install cultured marble shower panels
Posted by Terry Love on February 20, 1999 at 16:05:04:
In response to Re: How to install cultured marble shower panels
I always cut out and remove the existing walls and install new backer board. This gives you a chance to inspect the wood behind the walls, and gives a new surface for the "glue" that holds the new panels. For cultured marble, you will want to use greenboard.
: Hi, I need to replace the cultured marble panels in our shower, one has a hairline crack. I've installed tile before
: so I'm going to try this. I think the biggest challange will be to get the existing marble out without destroying
: the walls completely. Any tips, both on removing and installing.
: Thanks, Alan
Replies to this post
There are none.
