Re: Delta Faucet, Kitchen
Posted by Bill on February 17, 1999 at 08:53:47:
In response to Re: Delta Faucet, Kitchen
: : I have a leaky faucet in my kitchen. It is a general type from Delta. I took the handle apart and replaced most of the guts beneath the handle. Instead of leaking now, it seems to squirt water out from where the handle meets the mating surface? Any suggestions?
: : Thanks.
: bill, underneath the handle you will see a white packing nut delta has a tool that will fit in the slot. the tool comes with a delta repair kit. the nut needs to be tightened. dale problem solved.
DALE,
Can you tighten this nut with something other that this tool from Delta?
THANKS A BUNCH!!!! bill
Replies to this post
There are none.
