| Posted by dale's plumbing service on February 16, 1999 at 22:46:41: | |
| In response to Re: Delta Faucet, Kitchen | |
: I have a leaky faucet in my kitchen. It is a general type from Delta. I took the handle apart and replaced most of the guts beneath the handle. Instead of leaking now, it seems to squirt water out from where the handle meets the mating surface? Any suggestions? : Thanks. bill, underneath the handle you will see a white packing nut delta has a tool that will fit in the slot. the tool comes with a delta repair kit. the nut needs to be tightened. dale problem solved. |
