: I have replaced my wax seal for my toilet 2 times and it is still leaking. The first time I had to replace the vinyl. Now that there is new vinyl in the bathroom, the toilet is still leaking from underneath. The new vinyl is starting to ruin also. Does the toilet need to be replaced? I have a slab house. Thanks. well the stool could have a hairline crack in the trap. use a wax seal with foam in the wax.check between tank and bowl and check shut off valve.dry around stool real well and put tissue paper all around stool,then flush.
