: : I have noticed that the new 1.5 gallon toilet I installed in a rebuilt bathroom seems to be losing its water... : : Not all the time but many times, I go in and find the bowl empty. What could be causing THAT?? : : I'm on a septic system if that matters. : : Any suggestions would be appreciated. : : Thanks again,: : Rick : rick, did you change any venting in for the bath?does water leave the bowl when another fixture is being used, example a wash machine or another stool? do you have a sewer ejector pump on this line. Yes I did remove the cast iron elbow in the drain/vent line and replaced it with plastic. also tied the cast and plastic together with a rubber boot. I noticed it happening when the water in the bathroom sink was running once, but the shower and washing machine are on a totally different septic system. The kitchen sink is the only other drain connected to the toilet drain. Very small house... Does that help you any? Thanks Again, Rick
