Re: water in basement
Posted by dale's plumbing service on February 15, 1999 at 06:15:32:
In response to Re: water in basement
: I am at the end of my rope. Water seeps from under the floor and at the base of a north and south wall.
: What are my options? I cannot locate a hole for a sump pump - what would be a "ball park" figure to eliminate the water problem?
diane, there is no cheap way out of this one. it can be fixed 2 ways 1 dig up the out side of the foundation and install perimerter drain pipe around the house then to a sump pump and pump to the curb or away from the house or you can cut the basement floor and have the drain pipe laid under the slab then to a sump pump.
Replies to this post
There are none.
