| Posted by hj on February 09, 1999 at 01:58:58: | |
| In response to Re: Help! Where'd the water go! | |
If it happened to both lines, and turning the both on at the same time does not change the amount of water, then the aerator screen on the end of the spout is plugged. The best fix is to install a new one. : Hey, Terry. Hopefully you can help me. I was using the sink in the bathroom when the water stopped. A little is still coming out, both hot and cold but absolutely no pressure. It's not freezing outside so that's not the problem. Any ideas!
| There are none. |
