| Posted by hj on February 08, 1999 at 09:36:51: | |
| In response to Re: Rusted pipe | |
If the pipe is out of the well, then cut it off flush with the pump inlet, assuming you can get that close to it, and then use a hacksaw blade to make a cut through the side of the pipe inside the pump. Cut only about half way through it, and then use a pin punch to roll the remaining threads in and off the pump threads. Remove the deformed threads and install the new pipe. : While rehabing a pitcher pump, fitted to a
| There are none. |
