| Posted by Keith Thompson on October 24, 2002 at 18:33:27: | |
| In response to Re: Hot Water on Demand Systems | |
I installed an Aquastar 125 B April 2002. It's a whole house unit with a gas pilot. Works very well but I was suprised (shouldn't have been, I guess) when I read in the manual that the heat exchanger would probably have to be de-scaled in about five years (based on water quality). That will probably cost more than a new tank based unit! The promotional literature never mentioned this. : : Anyone have information on the systems that provide hot water on demand instead of a hot water tank? Is there significant differences between those that use electricity vs propane? : Tankless Gas Water Heaters : : : Read about a recent : Aquastar 125X $599.- is the : Aquastar 125 B $519. is the : Aquastar 125BS $599. is the : Aquastar 125 BL $569. is :
: Sizing and Models.. : For higher flow rate : Radiant slab, : Open loop : : Read the US Dept. of Energy's : 1. When a hot water tap is : 2. The gas is ignited by the pilot : 3. As you change the water : 4. The water temperature can be : 5. When the hot water faucet is :
: With an AquaStar tankless hot water heater by Bosch,- you'll : For ventless applications , check out the Power Venting : Questions or Service? : : : Want to see more? EMAIL US : Please check us out. We are members of the
| There are none. |
