| Posted by Rich O on February 01, 1999 at 18:00:40: | |
| In response to Re: Low water pressure in kitchen | |
LOOK UP UNDER YOUR SINK AND SEE IF THE WATER SUPPLY IS KINKED AND ALSO MAKE SURE THAT THE ANGLE STOP IS TURNED ON ALL THE WAY. : : Nancy:--The simplest solution I can think of is to clean any debris in the aerator that might be obstructing the flow of water through your kitchen faucet spout. If that doesn't do it, you may try calling the plumber that installed the bathroom faucet, to see if there might not be some corelation betwixt these two occurances. And if that doesn't bear any fruit, or increase the flow, You might try hanging a light in the window in the hope that the missing flow will return on its' own...Lots of luck...Bud : : After having a plumber replace the faucet in the bathroom (which is right off the kitchen) the water pressure in the kitchen sink dropped drastically. This was several months ago, and the pressure never came back. What would cause this, and is there a simple solution?
| There are none. |
