| Posted by Lucas on January 30, 1999 at 00:19:38: | |
| In response to Re: Not enough hot water | |
Are you supposed to drain your water heater on a regular basis? If so, I assume you kill the gas, and drain the water. I believe there is a self-filling regulator on top that will refill the tank. Then re-light and see how it goes. Ours runs out of hot water really fast and has a lot of sediment coming through our shower heads including calcium. |
| There are none. |
