Sump Pump Repair?
Posted by Gary Kadow on January 27, 1999 at 19:27:03:
I have a submersible sump pump that is acting up. The pump keeps switching on and then off with in a second or two. It seems to pump a very small amount of water before it shuts off. I assume the float switch inside pump is faulty. Is this something the average do it yourselfer can repair or replace? With the switch being inside the canaster, I'm hesitant to open it up. Other than the switch the pump seems to work fine. Thanks
Replies to this post
There are none.
