| Posted by Chris on August 23, 2002 at 10:23:01: | |
| In response to Re: slipper clawfoot tub | |
: HI: : I bought a slipper tub and now have found out that the plumbing is expensive. It is not a drilled tub so it must look good. The drain, supply lines and clamp is right around 500.00, and this isn't even the faucet! Is there somewhere more reasonable - it was suggested to me to make a wood box and enclose lines, and put a nice faucet on top. How would I do this? Thanks You can find many fittings much cheaper than $500. You can look at the following web site for some, and there are many others out there.
