| Posted by hj on January 26, 1999 at 00:10:11: | |
| In response to Re: can i install a bathtub | |
Can you? Yes. Should you? Probably not. If it is a replacement, then there could be access problems, or if it is the first one you have worked on. if it is a one piece tub/shower, you have to get everything in the right places first, and if it is cast-iron there are other coiderations. |
| There are none. |
