| Posted by Jonathan Maddock on August 12, 2002 at 12:32:27: | |
| In response to Re: Bathtub install | |
Shim out the studs to be even with the flange. : My question is: How do you install drywall (greenboard) around the fiberglass tub? It has flanges that you screw to the studs. Do you put the drywall right over those flanges and screws? It seems that this would be a little uneven and would crack the drywall. Or are you supposed to use shims to bring the studs out even with the flanges? Would appreciate any help on this.
| There are none. |
