| Posted by hj on January 23, 1999 at 23:11:58: | |
| In response to Re: Drain Cleaners used in plastic pipes? | |
unless it also has some kind of solvent, then yes. It should be listed as safe for all pipes on the label. : Can sulfuric acid drain cleaning chemicals be safely used on plastic pipes? Thank you.
| There are none. |
