| Posted by Lou on January 19, 1999 at 21:27:51: | |
| In response to Re: Cast Iron & ABS | |
On the cast iron in the slab cut it back to bare pipe no hub, then use a Fernco coupling, neoprene with two stainless gear clamps, to adapt to ABS. Ditto on the plastic to galvanized connection except you will need two 1 1/2" Fernco's.......Hope this Helps....Lou |
| There are none. |
