| Posted by Larry on January 19, 1999 at 17:22:30: | |
I'm converting a basement half bath to a full bath. RIght now, there's a cast iron closet bend running into a fitting in the slab. I'm assuming it's a hub rather than a no-hub (since everything visible is hub joints) but haven't broken out the concrete yet. Can I remove the iron closet bend and replace it with ABS if I use a neoprene gasket? Or, should the iron closet bend be cut short to provide a no-hub connection that can be extended with ABS? Also, is there a way to tap into an existing galvanized vent pipe without cutting it? Thanks. Hey, this website is the coolest thing. |
