Re: I need a water heater
Posted by MOHAN PATEL on July 25, 2002 at 10:41:44:
In response to Re: I need a water heater
: : Rheem is junk made in Mexico. State is a cheap. Bradford White is the best U.S. made water heater.
: Hello!!! just so happens that the bradford&white tank is made at the same place as the state! get your facts straight.
: : : : I need to replace a very old 40 gallon gas water heater which sits on old pine floors in my house. What brand would you recommend for efficiency and value? Do I need a pan?
: : : Rheem, state, are a couple of good ones. yes you should install a pan with a drain on it.
;; I need to replace two elctric water heater tanks which serve 10 one bed room units. Which brand is best!!!!!!!
Replies to this post
There are none.
