| Posted by hj on January 19, 1999 at 00:34:18: | |
| In response to Re: Price Pfister Shower Problem | |
Assuming it was designed as a combination tub/shower valve, then the diverter spout probably needs to be replaced. But if it was originally a tub, or shower, only valve, then it does not have the necessary restrictor installed. In that case there is no solution to the problem. : I have a Price Pfister faucet and shower installed in a bathtub, and when I turn on the tub faucet, water comes out of the shower head as well. There is little pressure coming out of the shower, but plenty of water runs out. When I pull the diverter, the shower works properly, and water does not come out of the faucet, but when I push the diverter back down, water continues to run from the shower head. Any help would be appreciated. Thanks.
| There are none. |
