| Posted by hj on January 16, 1999 at 23:03:41: | |
| In response to Re: need supply and drain for dishwasher | |
You need water supply source, often a 3 way valve on the hot water supply and the drain, which is often long enough, will attach to the side inlet port of the disposer. : I have an older home and with a baby on the way I would like to install a dishwasher . I ahve a garborator and I have done some plumbing and electrical . What heights and what do I need to hook into to make this work .
| There are none. |
