| Posted by Khamsi on June 19, 2002 at 21:40:35: | |
| In response to Re: Washing machine water automatic shut off valve. | |
You can also check out the intellfilow website http://www.watts-intelliflow.com : : I am looking for an automatic shut off valve. I had some major damage done by a ruptured hot water line, and was told that they make a valve that hooks up between the water lines at the valves and then to the washing machine. The valve plugs into the wall and senses electricity being drawn to the washer and opens the water lines. Can you help me locate a manufacturer? : Check out the Watts Regulator Company Model A-2 IntelliFlow. www.wattsreg.com
| There are none. |
