| Posted by hj on January 13, 1999 at 23:33:17: | |
| In response to Re: Leaking 2nd floor tub | |
Unless the water is overflowing the tub rim, how it is installed is immaterial, although the installation you refer to is done very often. The leak is most likely from the drain or overflow. : My 2nd floor bathtub is leaking into to room below. Last plumber recaulked tub sill and said to my wife that if that doesn't fix it I need to redo tile job. He also sid that the tub was an over-rim, although the tile is on top of the sill. : Questions: : 2. Can an over-rim tub be installed under the tile?
| There are none. |
