Re: shower pans
[ Follow Ups ] [ Post Followup ] [ Terry's WWWBoard ] [ FAQ ]
Posted by mike g in texas on June 01, 2002 at 12:01:00:
In Reply to: Re: shower pans posted by Jennifer on October 08, 1999 at 18:06:03:
: : : How does one know if it is the shower pan that is bad or if water damage to the bathroom flooring may be due to clogged weep holes in the shower drain and cracks in the tile grout?
: : Plug off the shower drain, fill with water and let set. Do you have another bathroom to use in the meantime? If every thing stays dry, the problem may be higher up. If wet, then there could be a fault with the pan. Another consideration, is the water supply piping. You may want to plug off the shower head and turn the water on to test for bad joints in the water supply. Terry
: Help! if you're concrete/tiled shower pan is leaking, is there any other option for sealing it other than tearing it out and replacing? What is the best solution for replacing it-one of those 3 piece shower stalls? retiling??
i just had a shower rebuilt.........except the contractor guaranteed that he only needed to cut off the pan at floor level and SEAL the new Dura-rock cracks and seams at the floor.........
after 3 weeks ..........leaks like a tea strainer........
What kind of pan liner do you recommend as best............?
thanks
Follow Ups:
Post a Followup
Name:
E-Mail:
Subject:
Comments:
Optional Link URL:
Link Title:
Optional Image URL:
