| Posted by Barry on January 12, 1999 at 12:47:35: | |
| In response to Re: Pedestal Sink Water Lines | |
: Most plumbers install water supplies at 8". I don't believe you will be able to "hide" the supplies for the pedastal lav, but you can try. You may want to look into good looking shutoff valves and solid risers for the supply lines. : Terry : : I need to move my waters in closer together for a pedestal sink to hide the connections. We have not yet decided on the sink. I would like to go ahead and move the water lines. What is the normal distance between the two lines for a standard pedestal sink? I agree with Terry. It's far more important to have fresh, good looking hardware than to move the stops. Of course, eight inches will correspond to the spread for the typical pedestal sink's valves, but a greater spread will not be that evident if there's good quality chrom hardware. You should not expect to be able to hide the stops behind the pedestal -- only the drain in back there. |
| There are none. |
