| Posted by michael mason on May 04, 2002 at 21:58:11: | |
| In response to Re: kitchen sink garbage disposal | |
: The garbage disposal is a two-blade type and I have rotated both blades with a plunger handle, pressed the re-set button (bottom of unit), and turned on the power switch, but I'm only getting a buzz. Any other suggestions? : It buzzed because it was jammed. You have to use something to rotate it counter clockwise and unjam it. It is not making any noise now, because the reset button has tripped. Find it, (usually on the bottom of the unit, but sometimes on the front), and press it to reset the switch. : : Can someone give me some trouble shooting advise?
| There are none. |
