Re: replace shallow well point
Posted by Keith L. on January 11, 1999 at 09:47:43:
In response to Re: replace shallow well point
The .22 cal. theory is a new one to me. But since you started down that path why don't you try the bigger is better theory, also. Since .22 cal. didn't complete the job .30 cal. is in order, if that doesn't work then .40 then .50 and so on, lastly if you don't possess any big calibers, 1/2 - 1 stick of dynamite will clear any and all obstructions. Or if a few of your dead brain cells have suddenly come back to life you could simply pull the pipe and foot valve replace which ever has the randomly placed slightly less than a 1/4' hole in it.
Replies to this post
There are none. |
