Re: cutting cultured marble
Posted by TOM on April 14, 2002 at 21:37:26:
In response to Re: cutting cultured marble
YOU SHOULD CUT CULTURED MARBLE OR ONYX WITH A MASONRY BLADE. YOU CAN ALSO GRIND IT WITH A DIAMOND DISK. WOOD BITS WILL NOY DRILL VERY WELL, YOU WONT HAVE ANY TEETH BEFORE YOU ARE DONE BECAUSE OF THE GRIT. USE METAL OR DIAMOND TOOTHED.
THE PRODUCT IS BRITTLE SO BE CAREFUL. WHEN I WAS A MANUFACTURER I PERSONALY CUT AND FIT CLOSE TO
10,000 TOPS. GOOD LUCK
Replies to this post
There are none.
