| Posted by TOM on April 14, 2002 at 21:28:47: | |
| In response to Re: cutting cultured marble | |
: : You want a fine sabre saw or circular saw blade. Cutting from the back side or using a reverse cutting blade is the best way to avoid chipping the materiao. Carbide will melt the plastic and gum up the blade. : : : I will be installing cultured marble in a bath/shower enclosers what is the best way to cut the marble to fit.Will a carbide blade work? The edges I cut will not be seen.Is a router better, are there any tricks to cutting...
| There are none. |
